CONDOR 350
RCASSIN
CONDOR 350
Post by RCASSIN »
Hi Guys...just got a Condor 350, Swiss military bike...has the Ducati motor. She starts right up, but has a lot of tapping, sounds like its coming from the lower motor, almosts sound like she is running with no oil.
can anyone tell me what they think the problem is? thanks rob
Chris Bushell
Post by Chris Bushell »
Assuming that the tappet clearances are correct, then it sounds like you are going to need to strip the motor and check it over.
It could be piston slap, but equally could be a loose clutch, alternator rotor or a big end flapping about.
Drain teh oil and look for bits of metal, if found do not run - strip it
Chris
Nick
Post by Nick »
Probably a rod big-end bearing.
RCASSIN
CONDOR 350 GEAR PROBLEM
Post by RCASSIN »
.Thanks for you response....She now wont go into 3rd and 4th gear...What do you think?????I appreciate your help!!!!
RCASSIN
gear problems
Post by RCASSIN »
Hi Guys.. I have a Condor 350, Swiss military bike...has the Ducati motor. Besides from be too noisey, she now wont go into 4th and 5th gear...Help?
Nick
Post by Nick »
Take the engine apart and check everything.
Gearbox locks up on the highway, the clutch won't help you, you're in serious trouble!
