I AM LOOKING FOR A STATOR FOR A RT450.
THIS IS A FOUR YEAR RESTORATION PROJECT THAT WILL NOT SPARK.
I HAVE NEVER HEARD IT RUN.
PLEASE HELP
RT450 STATOR
RT450 STATOR
SHOULD KNOW BETTER SCOT
- Diana
have you got lights working , brake and headlight, is the battery fully charged, if all is good, is the coil good, use your multimeter to see if you are getting a reading at the coil, and if none of that is happening which is what happened to me, check your earth, i made a bridging piece of wire with two alligator clips, put one on the block and the earth on the other and up she all went, bad earth was the cause
