DELLORTO PHF 32A (D) CARB SETTINGS FOR 1974 250 DESMO
desmo_duke1
Post by desmo_duke1 »
Hi
Having problems tuning this carb.Anyone know what jet sizes I should be
using.? Have the following jets fitted. :cry:
125 main
65 idle
50/3 slide
33 pump
AB265 atomiser
K3 needle
75 choke
What is the idle RPM supposed to be.?
What is the basic setting for mixture screw(turns out).?
Alan
Eldert
Post by Eldert »
Hi Alan
I would try a K1 or K6 needle . they are 2.45 mm diam
the K3 is 2.5 mm
you can find a needle chart at the Ducatimeccanica site
Eldert
desmo_duke1
Hi Eldert
OK....Thanks.!!
Alan :D
Vulpine2
Post by Vulpine2 »
I have the same bike. Standard fit was a square bodied Dellorto 29VHBmm carb, which was also fitted to the 350 and 450.
I don't have any info about the 32mm, which presumably came off a Darmah or similar? Haynes states a 125/122 main jet for the Darmah, so in comparison a 125 for a 250 would seem a liitle OTT
When my bike's (eventually...) back on the road I intend to fit a less restrictive silencer and replace the worn original with a new 30mm Dellorto plus K&N.
On enquiring with those that know about these things I was advised that anything above 30mm would be overkill unless the engine was heavily breathed on.
Be interested to know how you get on!
Rob
900ss, 350 SCR
UK
droydx
Post by droydx »
I'm running a 32 PHF on my 250 widecase.....it did take some finicking around to get it pulling smoothly through the RPM range. I have a green white cam, stock compression, ignition and it runs strong. Syd Tunstall smoothed the ports and I have one of his low megaphone pipes with an insert. It is easily streetable, but way loud!.
I'll have to pull the carb to check it and see what I have in there...didn't take any notes and I've had the bike for a loooong time. I'll check back tomorrow with what I find.
:roll: Ciao
Fun Ain't Cheap!
Droydx
