Hey,
Is there a special rocker that is used for the compression release mechenism. I aquired a comp. release valve cover and the plunger for the release hits the rocker arm and won't go on.
Thanks,
350 Compression release
Hi there
Ducati singles used 2 types off rockerarms. the solid type with used diff.
sizes lash caps and screw type adjuster rockerarms .
there where also 2 types off compression release valve covers
the cover for screw type adjusters has the release lever screwed into the cover . the cover for solid type has the compression release lever monted
into the cover with a nut underneed
if you want i can post pics
Eldert
Eldert
Hey Elbert,
Thanks for the help.
I've got the screw adjustment type rocker and the lever type with the nut underneath the valve cover.
Any suggestions?
Will i have an easier time finding valve cover or can the rocker arm be easily replaced with the solid?
Pics would be helpful.
Thanks,
Kyle
Any suggestions?
Thanks,
Kyle
Hi Kyle
look at the links to see the differance . i dont know what parts are easy
to find in your part of the world but at least now you know how they look
http://www.beneluxheads.com/album_showp ... ic_id=9399
http://www.beneluxheads.com/album_showp ... ic_id=9400
Regards Eldert
Regards Eldert
