F1A hydraulic clutch
hms86f1
Post by hms86f1 »
I need to remove the clutch slave cylinder piston and bearing inside the clutch cover.
Don't have the tools so I'll take it to a shop, but there are no Ducati shops within 200 miles of here.
I presume the bearing is first pulled out with a small (8mm) puller. True?
Does this require heat to be applied?
Any insights will be greatly appreciated.
hms86f1
Re: F1A hydraulic clutch
Post by hms86f1 »
Thanks Mr. Allen, for the tip about the grease gun, I'll give it a try!
