I need to remove the clutch slave cylinder piston and bearing inside the clutch cover.
Don't have the tools so I'll take it to a shop, but there are no Ducati shops within 200 miles of here.
I presume the bearing is first pulled out with a small (8mm) puller. True?
Does this require heat to be applied?
Any insights will be greatly appreciated.
F1A hydraulic clutch
- BevelHeaven Sponsors - Supporting Vendors Who Support This Place and You
- ↳ Click here to become a supporting vendor and sell your products
