pantah 750 engine temp?
Posted: Mon Jun 23, 2008 8:34 am
by weldingshop
So I went for a ride, all of 40minutes on a 78degree day; and when I got back I decided to aim a thremometer at the engine.........312-325degrees?
Has anyone else ever took the temprature of the f1 750 engine? Just curious as to normal or not.
Posted: Tue Jun 24, 2008 12:50 pm
by Peter Mille
Where did you measure it?
Heads will be (much) hotter, than other, f.i. lower, engine parts....
Posted: Tue Jun 24, 2008 1:24 pm
by weldingshop
Right on the Fins, heads,......and again Last night .....312.
Just Never did it and never read anything on the topic.
Any thoughts.
by weldingshop
Any thoughts.
Posted: Tue Jun 24, 2008 8:32 pm
by wdietz186
Keep in mind the temp rises after the engine is shut off. Also the rear cyl. on the F1 runs pretty darn hot anyway 300 ish doesn't sound too high though. If it were too hot you would probably get sone rattle under load. Look at your plugs and check the color.
Posted: Tue Jun 24, 2008 9:01 pm
by weldingshop
No she runs smooth as silk, even @twenty with 13650miles on the clock. I just used my thermal temp meter on it and thought 312ish was/could be hot.
funny thing is my 1098, show 210 but yet feels real hot on the donkey-sensor.
just getting worried about nuff'n.
Posted: Wed Jun 25, 2008 9:14 am
by Peter Mille
1098 = watercooled, F1= aircooled, no compare!
Posted: Fri Jun 27, 2008 6:46 pm
by wdietz186
Peter is right it's apples and oranges.The 1098 has a layer of water between the combustion chamber and the outer surface of the head. And a much greater surface area to dissipate heat. All the F1 has is the oil that circulates when the engine is running and the fins. I would put the thermometer to use on other things and enjoy the ride.
Posted: Sat Jun 28, 2008 8:38 am
by weldingshop
Lord have mercy;
yes i'm aware of the apples and oranges, and .....
Back to my lame attempt; can some one with a 750f1 or 750 pantah style engine take a 45minute summer time cruse not to exceed the speed limit and for the love of god please find the temp of the engine........just because. Or, i'm just damn curious.
And yes I will just ride it....[/code]
Posted: Tue Sep 23, 2008 6:33 pm
by carl750f1
I did the temperature test for you last week end.
The outside temperature was 74'F,I did a 40 min. ride and I took the temp. on the fins head near the spark plug.
The lower head temperature :300'F
The upper head temperature :282'F
I have a 750 F1 with Big Bore kit, Martin Brickwood Heads and Keihin carburetors.
Posted: Wed Sep 24, 2008 6:05 am
by weldingshop
Thank you, I was just trying to get some impierical info and needed some back-up. Those numbers fell in line with mine.
