350 gtl
les adams
350 gtl
Post by les adams » Mon Mar 29, 2004 12:31 pm
having just rebuilt the cylinder head and refitted it,and after retiming the valves by means of the timing marks, i find that the ignition timing is 180 degrees out!
how can i remedy this without taking the head off again?
Guest
Post by Guest » Sat Apr 03, 2004 7:08 pm
What would happen if you unpluged the ignition wires coming out of the points housing, and switch them around?
lazzer
350gtl timing
Post by lazzer » Sun Apr 04, 2004 11:28 am
unfortunately the ignition cam has only one lobe and this is now 180 degrees out,also the points back plate is not reversible, thanks for trying,L A
Den
Post by Den » Fri Apr 09, 2004 6:07 pm
deleted
Den
Post by Den » Wed Apr 14, 2004 1:05 pm
What I mean is to unplug the wires at the connector and then plug each wire into the other wire's receptacle. I made the same mistake and had to do it to mine too.
