Timing tool for 500 GTL
farmer fred
Post by farmer fred »
A buddy is resurrecting a 76? Ducati 500 GTL and the manual shows a special tool that attaches to the crank through a removable threaded plug, and a removable pointer, both necessary to set the timing with a timing light.
This model has points.
Is this a tool that is available, or is there a work-around?
Thanks for any help.
Tom3215
1977 500 GTL
Post by Tom3215 »
I also have a 500 GTL. It is perfect. Let me know if you find any tools available. I will buy also. In addition, I will email you if I find some so you
can buy if you wish.
Let me know if you see any parts bikes.
Tom3215
Wisconsin
Ken Shepard
Post by Ken Shepard »
You can do a static timing without the use of a light. The procedure is described in the GTL Workshop Manual here on Steve's site. Go to: Vintage Forun/Technical Info/Manuals Index, and scroll down to GTL manuals. See pages 8-10 for the procedure.
I have all three GTL manuals on CD. If you would like a copy, send me your mailing address.
Good Luck!
Ken
LAZZERI
Re: Timing tool for 500 GTL
Post by LAZZERI »
farmer fred wrote:A buddy is resurrecting a 76? Ducati 500 GTL and the manual shows a special tool that attaches to the crank through a removable threaded plug, and a removable pointer, both necessary to set the timing with a timing light.
I have seen this tool in "Vee Two" Ducati specialist web site: "veetwo.net"
I don't know if it fits parallels but it is very possible, ask them the thread diam.
French Ducati enthousiast
Owned many
At the moment busy with a 500 GTV and a 650 Pantah
my web site:
paralleltwins.com
esa
Post by esa »
They have the timing tool for sale:
http://www.ducati-gowanloch.com/new_arrivals.htm
Esa
Esa
LAZZERI
timing xweel
Post by LAZZERI »
go to my site:
open on my name LAZERI, open "paralleltwins"
You will find full infos in "mechanics"
:idea:
Owned many
my web site:
paralleltwins.com
LAZZERI
timing disc
Post by LAZZERI »
Gowanloch (Austalia) sells a special tool for these bikes
Owned many
my web site:
paralleltwins.com
Den
Post by Den »
You will find that trying to adjust the points using a strobe light and disc timing device can be...trying.
LAZZERI
Post by LAZZERI »
This tool is for sale at GOWANLOCH
see web site:
http://www.ducati-gowanloch.com/index.html
Owned many
my web site:
paralleltwins.com
