ignition parts
nsu max
ignition parts
Post by nsu max »
I'm looking for a point plate to buy for my 500 GTL the original mounting plate has two tabs too screw the point springs too, the new points I've got do'nt use these tabs and wo'nt fit the old plate, the plate they mount to is flat. If memory serves me there was an update to use 750 v-twin points instead of what was used originally on the parallel twins and these may be the points used for that update. any help or assistance would be appreciated. Thanks
LAZZERI
Post by LAZZERI »
Very difficult to find...
I had the same problem with points from Giovanni Gentile, theyn don't fit.
The best if you want to be cool with spares is to buy an old bike at a breaker's.
Or, if you are ready for some expense buy an electronic ignition kit at this adress:
http://www.elektronik-sachse.de/index_en.htm
Ducati Saluti !
Gerald
French Ducati enthousiast
Owned many
At the moment busy with a 500 GTV and a 650 Pantah
my web site:
paralleltwins.com
nsu max
ignition parts
Post by nsu max »
Thank you very much for the information, I beleive we have supplier for these ignition systems here in the states. I'll keep you informed.
Thank you
Frank
