G'Day Steve,
Quite some time ago I installed the kit you supplied.
I am have just blown a fork seal so plan to disassemble clean etc.
When I first installed the spring kit i discarded the spring tube part # 0795.37.340.
I have spent ages reviewing the chassis and suspension forum but can find no reference to this.
Was I correct in discarding this bit
The ones I removed look much longer than the pics of the ones with that part # in your shop
thanks
garryc
works performance spring kit
Re: works performance spring kit
yes that shroud thing is no longer needed with our correctly sized spring kit....
- ::: UPDATE ::: -
Works Performance closed up when the owner died. It has since re-opened under the new name WORX SHOCKS.
Gil's daughter has finally managed to get everything setup again at a new location, using the same engineering drawings so you will get the same great products. Some of the same employees are running things as well. We all wish them continued success.
We have inventory on the shelf of 35mm and 38mm fork springs kits again and, we are once again taking orders for custom built shocks like we used to do.
https://store.bevelheaven.com/Shocks-Fork-Springs/
