How to seat lower headset bearing inner race?
Peter Tourin
Post by Peter Tourin » Fri May 05, 2006 4:50 am
When you replace the lower headset bearing, how do you seat it? Do you fabricate a tool that's a pipe with the proper ID to drive the bearing evenly?
Thanks - Peter Tourin
'73 Volvo 1800ES
'74 750GT
seating races
Post by BevHevSteve » Fri May 05, 2006 8:11 am
yes - just a piece of pipe and pound it on. You can heat up the race to make the inner hole daimeter larger and it will slip on also.
Peter Tourin
Post by Peter Tourin » Fri May 05, 2006 6:36 pm
Yep - I realized that regular black pipe from the plumbers supply is about 1" ID and just fits. I just stuck a piece in the lathe and trued one end.
The outer races look simple - I assume that if I stick them in the freezer and heat the frame gently I can tap them into place pretty easily. Any tricks that'll help?
Thanks - Peter
'73 Volvo 1800ES
'74 750GT
bearings
Post by BevHevSteve » Fri May 05, 2006 8:46 pm
3/4" all thread, several large washers and a nut on each end. Tighten them up to seat them. voila
