Hi does anyone know where i can obtain a rear frame loop for a wide frame 750 gt , the previous owner has butchered the loop off,so i cannot
fix a mud guard to the frame
regards andy
Rear frame loop for wide frame 750 gt
- SSD900 Darmah
Just sold the one I had but you should be able to fabricate at least a functional replica of the original with some careful measurements from another bike. There are no compound curves and its plain round mild steel tubing though you don't want thin wall tubing. Its spot welded to the frame in two places on each side, top and bottom where it slides into the frame tubing which is larger in diameter. The bracket for mounting the fender and tail light is welded to the loop. Here again if you can find a bike to look at or get pictures and measurements it should not be too difficult. FYI: I got $50.00 for my rear loop. Was happy to help the guy out and I wasn't going to use it but I have not seen any others for sale anywhere. A competent fabricator can probably make one from a pattern in a couple hours.
Good Luck, Jordan
Good Luck, Jordan
