Darmah SSD Pillion Footrest / Silencer mount
Posted: Mon Jan 27, 2014 3:22 pm
Hi Guys,
I'm looking for some feedback here please. According to the attached parts diagram, the pillion footrest bracket is attached by a bolt through from the inside, into the footrest hanger. I've not yet found an online manual showing the silencer mount.
Now, my SSD has been fitted up with 10mm through bolts / nuts, attaching both footrest brackets and the silencers to the footrest hangers. The corresponding page shows part 18 to be a 7/16 x 20 set screw.
My question concerns how the silencer should be attached to this bracket? Does it use another 7/16 x 20 set screw, entered from the outside, short enough not to bottom?
My temptation is to use one long 7/16 x 20 bolt, right through the whole lot with a nyloc nut on the end. Your ideas / thoughts/ comments on how it was originally fixed would be welcome.
Regards
Colin
Regards
Colin
