38mm damper rod pistons
gavin
Post by gavin »
Hi all,hope everyone had a good festive break.I am doing a front end overhaul(spring broke) and noticed the damper rod pistons quite loose on the rod,about .9 mm between rod size and bore in piston.they are both basically the same so my question is should they be of closer tolerance,they are held by circlips so not sure whether they are meant to float a bit to compensate for flex etc.all the tech data I have found advises inspect and change if worn but no actual measurements given(I just love Italian manuals)
cheers Gavin
