I know most Bevels had there compliance plate positioned on the right down pipe of the frame.
If you were doing a restoration with plate in hand & looked everywhere and could not find anywhere on the frame where the holes for the rivets were , where would you re-mount it ?
Australian compliance plate positioning
- BANNED
The compliance plate on my bike is a type of foil and would have been glued on, not rivetted. Are Australian bikes different?
Could someone post a photo of the mounted compliance plate? Mine has been relocated to the rear mudguard and I should return it to its proper place.
Thanks,
Thanks,
- BANNED
Bugger about some saying that its on the down tube and other are saying it should be on the steering head stock , I might have to do some more research on the subject
Bruce , the US had both hard plates and sticker type and most are fitted to the steering head stock , I'm having mine remade [ sorry cant say where or by whom]
compliance plate
Rough I know but mines on my bench in the shed, Itook it off to get the frame powder coated and the RTA guy did`nt seem to care it was mounted in my pocket when I went down to rego it. Mind you he was full of "hey nice bike mate" and just seemed glad to see it on the road. You just got to find an inspector with soul brother.........................
Long story short theGTS had it on the head stock, the SS on the frame down tube
- BLABBERMOUTH
plate
Hi Martin,
Just rechecked the size of my comp plate.
Its way way bigger then what shows in steves pic,so obviously if its small like in the pic its meant for downtube.
Steering head plate is at least 40mm wide and 70-80 mm long.Hope this helps ya out.
KRACKA
KRACKA
- BANNED
Martin,
My 82 MHR is mounted RHS frame rail similar to Steves Photo, My 12/79 SSD is on the headstock and is also a larger /squarer plate than that on the MHR.
79 SS an English import and no plate fitted.
NCR replica frame I mounted under the seat on an Alum plate, when I had rego check I was asked where it was and was told it needed to be "visible without removing any bodywork"- go figure that one on an MHR with the fairing fitted!
Anyway, hope that helps along with other feedback.
PM me please about your "new plate" we may have a similar friend.
Grant
Grant
