Marzocchi AG Strada; Improvement questions
Jon
Post by Jon »
Hi
Has anyone any expeience with Marzocchi AG Stradas other than throwing them in the bin?
I am putting Cartridge emulators in the Marzocchi forks on the front of my S2 and respringing it for my weight and was wanting to improve the handling/ride on the rear whilst keeping the AG Stradas.
The current plan is to check the rider & Static sag when I get the bike assembled, spring them for my weight and put some light fork oil (5W) in them to see how they feel.
I have the AG Strada maintenance sheets off the net and they have a small table for different diameter shims for different settings, am guessing that this is for compression only and the rebound is taken by the foot valve.
Any help would be great.
thanks
jon
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
Kickaha
Re: Marzocchi AG Strada; Improvement questions
Post by Kickaha »
Jon wrote:Hi
thanks
jon
I have just had mine rebuilt and are waiting for them to arrive so I can try then, in the meantime I bought a pair of Ohlins for the rear so will be able to do a back to back comparison
The Ohlins certainly feel like they give a plusher ride
I'll be interested in how your front end performs as I will be doing the same modification as soon as I can afford it
Eat Right
Stay fit
Die anyway
Vince
750 Sport [BEVEL]
Post by Vince »
If your keen on keeping the Maz on the rear I hear Race Tec is moving into the classic bike market,maybe you could get them to upspec the Maz internals
Jon
Post by Jon »
Thanks guys.
Would be interested in how you find your rebuilt rears Kickaha, do you have any info on what they did with them, will post up some info on my fronts when I am back from work and then again when I get it on the road.
Thanks for the heads up Vince, will check them out.
regards
jon
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
Peter Mille
Post by Peter Mille »
The AG Strada tend to leak rather soon.
I had mine overhauled by an Ohlins/ former White Power suspension specialist, he did redesign the shaft support, and he did use better, non foaming oil.
He also advised against using air in them, to protect the seals from blowing out.....
It's been about ten years since the rebuilt, still no leaks, (and I use them upside down!!).
