Stop laughing all of you...... I am looking for a set of rebuild seals for the old marzochis with 10mm shafts. About 78 -79 vintage.
Someone must have some or know of someone who has them. I have sucessfully dismantled my set and need new seals.
I also would like to know how much oil would you put back in them and what viscosity if you were a 105kg bloke like me!
Appreciate any serious answers and not just raucous laughter!
Giggles acceptable.
A source repected.
10mm shaft marzocchis- anyone got rebuilt kits?
Grant
Grant
Thanks Kracka,
I got onto a place in Penrith NSW called SOS suspension, they gave me the oils info.
His advice- fill the inner chamber full with oil (weight dependant to your dampening desires) (read body weight 105kg) for me and a pillion I will use 15W, after the inner chamber is full, allow the oil to fill the main body to approx 1/3 capacity. remember to keep the internal chamber full.
THEN replace dampening rod /shaft into inner chamber and then begin reassemble.
I am sure there are "exact capacities" floating around somewhere but these sound about right and I will advise once done how it all works.
Gowanlochs had the seals but no dust seals, so got them coming, still obviously look for dust seals though
Will keep the post informed anyway in case others are looking to rebuild old SS shocks
Only dust seals to go....help?
Grant
Grant
- BANNED
Realise you are only after dust seals now but www.mdinaitalia.co.uk lists
"Marzocchi rear damper rebuild kits. AG Strada....#21.43 ET85 models with 10mm damper rod....#31.43."
regards
jon
regards
jon
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
Jon,
Yeah mate saw them and spoke to Andrew at Mdina, they are the exact rebuild kit that I was told I couldnt get here in OZ,
The kits are the replacement "heads" off the shock body that contain the seals / dust wipers all in the one unit. I bought the pair he had on the shelf.
Also now have spare seals.
Thanks for all feedback on this one to all, job I hope now complete apart from paint and put back together and try out. Will get stickers for shock bodies from Motographics in Sydney (round marzochi sticker)
Grant
Grant
- BLABBERMOUTH
The set I have have the crimped nuts and they were the replacement heads I bought from Mdina.
Ive finished the rebuild of these now, they work fine, have also rebiult a set of Stradas (black bodies) and now coninue to look for ONE 79ss shock to complete my set off my 79 English 900 SS-- Help?????
Grant
Grant
