Jetting
Posted: Tue Mar 30, 2004 6:35 am
by Peter Freiberger
It was suggested I go with a 125 & a 130 main jet for my Sport's 32's. Opinions? And which carb gets which jet?
Thanks,
Peter
jetting
Posted: Tue Mar 30, 2004 6:43 am
by Eldert
Hi Peter
Allways put the bigger jet in the rear , the exstra fuel helps to cool
the rear cilinder
Eldert
here's my jetting for 32mm Dellorto carbs on a 750 GT/Sport
Posted: Mon May 24, 2004 8:35 pm
by hulagun
I have Sport pistons in my 750 GT with stock 750GT cams and valves, 32mm Dellorto pumpers, port matched manifolds, dyno tuned by a bevel specialist. Runs perfect.
needle: k5
main: 125 front and rear
pilot: 65
needle jet: 265AB
slide: 70/2
float valve seat: 250 with pink valve
float bowl jet: 75
venturi jet: 35(?)
Ivan in SF
