I have recently pulled both 17mm fuel taps apart from the 750GT (OM Setti Vignola) and as suspected, the internal rubber seals are shot. No problem, you say.
What I have noticed, however, is the surface of the tap face (the bit that turns) has lost some of its chrome (or similar) plating, revealing what appears to be the brass material that the tap is made from.
My question is thus, does anyone see a problem if I lightly sand the face of the tap across a flat surface with a very fine wet'n dry?? The result would obviously be total loss of the original surface but will restore it back flat and smooth at least.
Fuel Tap Question
- Mariana
- BANNED
