Crankcase full of fuel
abmartin
SSD900 Darmah
Post by abmartin »
As noted earlier, there are two different ways in which fuel is prevented from overflooding the carbs - at the tank taps and at the float bowl inlets. Both should be checked for to ensure they seal properly. If the problem persists you may want to consider changing the taps for a non-vacuum style.
