Cables for PHF Delorto's
I just purchased a 1979 900 GTS. The carbs have a single cable at the throttle, and the kit I ordered said it was for PHM's. This bike has PHF's, but the cables look right? So will a single pull throttle kit work OK with my PHF's ?
no
the cables for PHF carbies are shorter than required for PHM carbies
SINGLE CABLES
Hi,
further to what Steve says... from what I gather, and it makes sense, the single cable goes to a fitting from which the 2 cables go to your carbs. fit a dual cable twist grip & it all becomes easier and runs better. you can tune & synchronise the carbies quicker & easier, less parts to wear.
I did it years ago on my 750 GT ..makes a lot of sense..works better..do it!!!
Rickf
Rickf
I concur. THis is the best method - tommaselli DAYTONA 2C throttle with 2 cables [only] each cable going from throttle to carbie. I stock everything you would need.
not a problem Phil, it is done.
