What's the best way to (a) stop petcocks from leaking fuel from where they attach to the tank and (b) align the lever in the front without having the petcock too loose ?
I have tried using mulitple fiber washers, o-rings and teflon tape. All seem to work for a few days, then.....drip drip drip...
Steve sells some stuff in a tube on Bevel Heaven - My guess is that is the stuff to use.
Tony
weepy petcocks
weepy petcocks
Tony
70 450 Jupiter (Scrambler)
74 450 MK3
61 250 Diana (project)
66 250 Mark 3 (project)
66, 67 250 Scrambler
65 125 Bronco
76 Vespa Ciao (my daughter's)
74 450 MK3
65 125 Bronco
good guess yep this will do the trick
http://shop.bevelheaven.com/detail.aspx?ID=595
PERMATEX high temp thread sealant. Perfect for 900SS and singles fuel taps - the ones that thread INTO the tank, bleed screws on brakes, brake light switches etc. Fuel, brake fluid and oil proof. This is the good stuff baby. Comes in a 6ml tube.
Click the link then click the photo for a larger photo so you can see the permatex part #
