Choke splitter box location
Mick b
Post by Mick b »
I'm finally getting to the reassembly stage but can't figure out where the choke cable splitter box bolts to the frame, if indeed that is the case.
Just for clarity I 'm referring to box that has one cable from the choke lever going in and two cables going out one to each carb. Mine is the square type and has what seems to be two mounting holes on the base.
Thanks in advance
Mick
Re: Choke splitter box location
doesn't bolt to anything. That said on every bevel I have restored I set things up then zip tied it where I wanted it to stay (loosely).
Mick b
Post by Mick b »
Many thanks that simplifies matters.
