Darmah Front cylinder running rich
Cagiva Gran Canyon
Re: Darmah Front cylinder running rich
mdal8798 wrote:
Wed Jul 22, 2020 1:19 am
Pickups and wiring are are in good condition ... Resistance measurements are within specification <snip>
Well, I guess that's progress, Mark ... in a way :roll:
So, is it still banging and popping on the front? Back to basics, then:
- Have you checked the valve clearances?
- Don't forget the plug cap and lead (Unscrew the cap, cut the lead back a tad, wipe it clean, re-fit the cap. Use a new one, by preference - and of the right resistance)
- Check the quality of the connection at the coil too
- And of course fit a new plug
- You could also try swapping coils
- Exhaust sealing properly?
I have contacted Gowanlochs in Sydney ... he is of the belief that i just need to get bike on the road and basically blow the cobwebs out of it first then look at idle setup later.
I will freely admit that this kind of advice, especially when coming for a professional, always concerns me. Because if something is wrong, 'running it down the road for a few miles' it just as likely to make things worse as to magically resolve the problem. But each to their own ...
The advice from 900tlc about changing the ignition system is well-founded, however. All depends on how much time and money you have, and how frustrated you get chasing faults :evil:
@ 81mhr900ss: excellent advice as always. However, when Mark swapped the carbs over, the problem (banging and popping) stayed with the same cylinder (the front). Which suggests that the problem is not carb related.
Understood and agreed. After pulling out all the old stuff, I was able to determine that the likely culprit for my initial pre-Sachse lumpiness was the front coil. I'm very happy with the decision to go with a new ignition system.
Cagiva Gran Canyon
81mhr900ss wrote:
Thu Jul 23, 2020 8:40 pm
Thanks for the info. Tell me, did you have Motoplat (red) or Nippon Denso (off white) coils ? Just being nosey ... :-D
Nippon Denso were the original coils on my 81 MHR
Cagiva Gran Canyon
81mhr900ss wrote:
Fri Jul 24, 2020 11:23 am
And sometimes Motoplat :). But I guess you had N-D, right?
