geodoc
Post by geodoc » Sun Jul 21, 2013 11:18 am
Hello,
Looks fairly likely (pending the owner's sorting out the ownership paperwork) that I will be acquiring a rolling basket case '73 750GT. If the trigger actually gets pulled, I hope to use the board resources to locate some of the missing parts as well as information on practical mods and engine overhaul data.
The bike has had the engine removed and disassembled for (so the owner says) about 10 years. The engine parts have be stored in a covered, but unheated place most of that time. I had a look at what's there and a couple things became apparent. First and worst, both cylinders have gone missing, likely grabbed by a street person metal recycler. Also see that the entire exhaust system is missing. The crank has been pressed apart and the rod wear surfaces at the big end bores show light scoring and corrosion damage, likewise the crank pin. Otherwise it looks like all the parts are there, though rather mixed up with various shims sitting in the bottom of one box. Light, but not as what you could call potentially damaging corrosion on studs, K/S shaft, etc.
The rolling chassis was in a different location and is fairly complete - also stored inside, but not heated. It is missing one instrument can't remember if it was tach or speedo). The front rim has been replaced with a shoulder less aluminum one. The tank has little rust inside. fenders, tail light, headlight, etc. are there. Little rust on the fork tubes.
So .................... if the owner can get the ownership paperwork sorted, he has proposed a pretty reasonable price to start negotiating. If it happens, then I need to assess whether it is sensible to attempt a restoration or just clean it all up and flog it off piece at a time. My inclination is to restore it, so I'll start out looking for a pair or cylinders and take it from there. Anybody have a pair?
I'll probably find out if this is going anywhere this week and will update.
George
enforcer
Post by enforcer » Mon Jul 22, 2013 6:33 am
pics...?
geodoc
Post by geodoc » Mon Jul 22, 2013 8:09 am
enforcer wrote:pics...?
If I get it, then there will be.
geodoc
Post by geodoc » Mon Jul 29, 2013 6:03 pm
Was able to seal the deal and get the ownership paperwork. Picked up the boxes containing the engine parts and a few misc. bits like side covers, kick starter lever, side stand, etc. Tomorrow I'll pick up the rolling chassis then clean, sort, inventory.
geodoc
Post by geodoc » Tue Jul 30, 2013 5:48 pm
Got the rolling chassis today ...................... well, rolling after I removed the seized front (Lockheed) caliper.
Image[/url]
Image[/url]
Post by BevHevSteve » Tue Jul 30, 2013 11:37 pm
Looks like you are in for a fun project there..
geodoc
Post by geodoc » Wed Jul 31, 2013 2:23 pm
BevHevSteve wrote:Looks like you are in for a fun project there..
It's going to be a slog, but worth it in the end me-hopes.
Lots of info to absorb, not having previously been amongst the beveled. A Guzzi oriented person in the past.
thessler3
Post by thessler3 » Fri Aug 02, 2013 1:47 pm
You have an unusual machine there. Most 73's had a fiberglass tank in the US. Your rear shocks do not look like stock either. It has the stainless fenders which are nice. Have fun finding those cylinders. I seem to recall a site in the UK which might have them.
geodoc
Post by geodoc » Fri Aug 02, 2013 7:33 pm
thessler3 wrote:You have an unusual machine there. Most 73's had a fiberglass tank in the US. Your rear shocks do not look like stock either. It has the stainless fenders which are nice. Have fun finding those cylinders. I seem to recall a site in the UK which might have them.
If you remember the place in the UK that might have them, please post.
Started cleaning, inventorying and inspecting the engine parts today. Nothing obvious for trouble (the crank pin / big-ends which I knew already) except a ruined kick starter shaft spline. Seems that I read somewhere that an 860 / 900 shaft assembly would work as a replacement.
A number of 'mystery shims" that were in the bottom of one of the boxes with (among other things) gearbox parts.
Layshaft 5th gear is stuck on the shaft. Not seized, just stuck to where I'll need a puller to get it off. Odd .................... I've also heard that there are some lubrication mods that can be incorporated into the gearbox, though nothing specific as to what those mods might be.
Clutch hub has considerable notching from friction plate splines. Very little on the basket segments from metal plates. Heard of a (surflex?) replacement that provides adequate grab, but requires less clutch lever effort (lighter springs?). Longer clutch actuator arm is available (recommended?)
How the &$)@*@ do you get the snap ring out of the breather housing w/o stabbing yourself in the hand w/ the awl I'm trying to get under the end with?
GD
Steve Foster
Post by Steve Foster » Fri Aug 02, 2013 11:19 pm
Just saw a set of cylinders on eBay from AMS Ducati Dallas (214) 466-6540.
http://www.ebay.com/itm/1973-Ducati-Bev ... cc&vxp=mtr
http://www.ebay.com/itm/1973-Ducati-Bev ... 43be4c4c88
Good luck with the project.
Steve
1974 Ducati 750 GT
geodoc
Post by geodoc » Sat Aug 03, 2013 8:24 am
Steve Foster wrote:Just saw a set of cylinders on eBay from AMS Ducati Dallas (214) 466-6540.
Steve
Heh Steve,
Thanks for the heads-up. My hope is to be getting a pair of barrels from another source for considerably less, but if that doesn't work out, maybe these will.
GD
geodoc
Post by geodoc » Tue Aug 06, 2013 6:40 pm
Steve
Heh Steve,
GD
Bought them both.
Thanks again for the heads-up.
geodoc
Post by geodoc » Tue Aug 06, 2013 8:21 pm
The rolling chassis is set aside for the moment while concentrating on getting the engine parts cleaned, inventoried and inspected.
Almost finished with getting the last of the engine disassembly - bearings all removed from the cases, distributor disassembled, one head striped & one to go.
Pleased to see that there is very little wear / damage on any gear teeth or dogs. Shift forks show minimal wear.
One problem with kick starter shaft (315mm type). It looks like the kick starter was loose at some point and the through bolt wore into the splines. I've had no good suggestions for ways to make a permanent repair. This shaft is apparently available reproduced for about $400 CDN. Not wanting to assemble and just hope that with the kick starter lever well cinched down, it won't end up with further stripped splines and then having to re-split the cases to deal with it, I'll probably spring for the new shaft.
I noticed that there are two kinds of valve covers in the pile (3 'shallow pocket' and 1 'deep pocket'), though the parts book only calls out one type. The folks at BevelHeads informed me that the "deep pocket" type were for later models that had conventional screw type valve adjusters. This one has variable thickness lash caps, so the 1 odd cover is a replacement & will go on the less conspicuous rear cylinder intake position.
geodoc
Post by geodoc » Fri Aug 09, 2013 8:14 pm
Cases are all cleaned and inspected. The reason for the disassembly may have revealed itself. I see that in the RH case, above the drive sprocket that there has been a weld repair done. Looks like the chain let go and knocked out a chunk. The repair looks very well done (my machinist / welder friend had a look and pronounced himself impressed).
Interesting too is evidence of other welding - the lower fin on the RH sump case half has been repaired by the build-up and grind down method as you can see in the picture below. Again, very nicely done. There other evidence of grinding, though no internal evidence of welding on the RH sump. Trying to fix a porosity leak?
There was also some grinding evidence on the RH case, forward engine mount boss. Very hard to tell whether it was welded or just just ground for a bit of aesthetic smoothing.
Previous owner looks to have been less than diligent on keeping his chain adjusted too.
Post by BevHevSteve » Fri Aug 09, 2013 8:53 pm
Thanks for posting all the pix - keep it up!
one of my case saver kits will help keep the chain from grinding into your case (typical things for all bevel twins actually)
A tip for making the cases look less like there has been grinding etc is to use a very course sand and sand plast the aluminum where it was ground or wire wheeled. With patience you can hid that pretty well from glances... You will always see it of course, but the casual observer may not notice.
