Page 2 of 2
Posted: Wed Aug 31, 2005 7:59 pm
by Guest
Hey Geoff,
Is the image server down temporarily or something else? The last few pics aren't loading... can it be fixed?
C./
Posted: Thu Sep 01, 2005 4:17 pm
by DesmoDog
cshannon wrote:...Is the image server down temporarily or something else?
Looks to me like the links go to a file on a hard drive instead of an internet host?
Posted: Thu Sep 01, 2005 5:13 pm
by Guest
Well spotted Craig!
Yeah Geoff, you'll need to upload them to a free image host like you did with all your other shots.
Let me know if you need assistance or just read Steve's notes on how-to at the top of the Gallery index.
C./
Posted: Thu Sep 01, 2005 5:14 pm
by Geoff
That's cos I edited the file names to something meaningless as, when I checked after Shanner's complaint, the xs.to seems to have lost the files for some reason and I didn't have them on my computer at work. I'll update tonight....
Posted: Thu Sep 01, 2005 5:34 pm
by Guest
As far as free images hosts go,
http://www.photobucket.com seem pretty good.
Posted: Thu Sep 01, 2005 6:40 pm
by Geoff
Ok; I've done it. hopefully y'all can see them again now. Don't know what happened. You two are a pair of hard taskmasters.
If I can get the camera out at the weekend I'll upload a few more of the 'finished' product.
'Finished' because I thought it was at the weekend.
Over the past two months (including 3 weeks vacation back home in Blighty and France...) got the heads & barrels off, stripped heads, checked guides (ok), changed guide seals (knackered), deglaze honed bores (bit worn), and fitted new rings. She's stopped smoking when I got her running at the weekend.
Trouble is, the battery's not being charged, no response on the AVO when revved at all. And in May it was putting out loads a volts. Not sure if I buggered the regulator/ rectifier by running it against a knackered battery last week for a 15 minutes, or damaged the stator/ gen wiring when I had the engine cover off. I do know that tonight when I put the Vac AVO on the stator output directly I was getting max 3V at 5k revs.
So, some more fun. Not.
Cheers lads!
Posted: Thu Sep 01, 2005 7:05 pm
by Guest
Nice one Geoff! You're a legend.
A question, is that bit of blue sticking up above the frame a tank fastener?
If so, where did you get it, or did you make it and from what stock?
C./
Posted: Fri Sep 02, 2005 5:14 pm
by Geoff
Indeed Chris if that bit lies on the tank and grips around the frame she's very effective in that regard. She also comes with quite a bit of baggage.
I knocked her up from some left over bits of fluff from the 60's, nothing you should have any trouble finding down the Rocks on a Saturday night....
Cheers and trebles all round etc
Posted: Tue Oct 04, 2005 7:28 pm
by Geoff
Ok; update & pics time again.
After the smoking 'incident' was fixed (see above) I had the problems with charging; well the stator was fine, but the reg wasn't earthed properly. When I improved the reg earth I got 18V output!! So I had knackered the regulator (or it was just on the way out anyway?) Fitted a moplat one and 14.8V thank you very much. Battery fine and stays charged. Whooopppeee!
Had some hesitation problems which I was unable to accurately pin-point, but was planning a change out of the two 6V PVL coils on the Rita for a dual output 'green' 3 ohm Dyna anyway and for whatever reason the problem went away (perhaps the 18V out of the old reg knackered the coils? Or perhaps there was a poor connection in the system somewhere? I also flushed the tank again and rebuilt and cleaned the carbs - again! And fitted in-line fuel filters).
Performing a voltage drop test on the +ve side revelaed some about 0.75V drop between the battery terminal and the new coil, so I cleaned up some of the connections again and got that to 0.5V which is very acceptable.
Whatever, done a few miles on it now - even changed the oil after 250 miles! - and it seems to be holding together fine. Last weekend up to Italy, TX (I kid you not) with some buddies for an Gu$$i rally (to be honest I was trailered up but did get in >200 miles riding up there). Very happy with the performance, though constantly nervous something might break of fall off! I'll get used to it. Oh, and I ran out of gas; didn't realise it drinks petrol if pushed.... Must get new Smiths trip knob!
Here's a couple of pix at the camp site:
Geoff
bella
Posted: Wed Oct 05, 2005 7:50 am
looking good Geoff.....
