900 S2 tidy up
Jon
Post by Jon »
Updated last post with more info on the paint I used on the wheels.
regards
jon
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
freckle
Post by freckle »
looking good!
Ya better hurry but you dont want ya Son to get his bike going first! :-D
Smooth is fast.
Jon
Post by Jon »
Been a fair while, been a bit busy with work and building my parents a house when off roster.
With the bike sitting around the bolts were get surface rust as the zinc was gone, would have been annoying to get it finnished and think "Would look OK if the bolts weren't rusty" so I stripped the bike again and got all the fastners, axles, footpegs ect zinc plated at Pine Rivers Electroplating.
Bought 2 rear inner guards off different people (no-one on this forum), one was wrong model and other was in worse condition than mine, only upside was that although it was broken in the same area there was enough bits between the two to make one.
Before
After
Got the Q-Bond from Repco, pretty happy with the results, will see how it lasts.
Layed up the decals from CutGrafix, sorry about the crap photos, but ones on camera died and only had this one on my phone.
Got myself a ride bike while doing up the S2.
Jon
Post by Jon »
Rebuilt front forks;
I got the Stanchions rechromed by Rad Hard Chroming
Fitted Cartidge emulators and Springs from Suspension Improvements
To fit the Emulators I had to do some mods to the Damper rods;
Filling in a drilling some more holes to redirect oil flow
Mahine check valve out of top and fit a locator ring.
Pic of Emulator fitted
Got it back on its wheels this am, main fairing should be back from painters early in the new year as I put the main stripes on crooked :( so had to order some more.
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
Ta Jon. "Keep on truckin ..."
Don't forget to report back on what you think of the emulators, as and when ...
Macdesmo
Post by Macdesmo »
Jon,
What is the quality of the electroplating from Pine Rivers? I need to get another plater as my current one is too slow.
Ian
Jon
Post by Jon »
Ian
Found Pine Rivers pretty good, I only got zinc plating done but the quality of that I am happy with.
Also had a look at another couple of chrome plating jobs that they had there as I will want some done later, also looked pretty good.
They turned my stuff around in 3 weeks, I did tell them that there was no real hurry as I wouldnt back until then anyway so not sure what their "normal" turnaround is like.
I will use them again.
jon
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
Jon
Post by Jon »
Got the motor back from being glass bead blasted yesterday evening, plated up the Intake, Exhaust, starter motor hole, breather tower and plugged clutch rod hole so fingers crossed.
Was going to get is soda blasted but the guy that did it for me recomended the glass beading, I am pretty happy with the results, blasting took the last of the zinc of the bolts and head nuts so they are now rusting :?
Son helped me get motor into frame, starting to look like a bike again.
Need to pull off the side covers and bevel tops and give them a polish.
Wheeled the bike backwards and the whole speedo drive went around backwards with the wheel, I didn't noticwe until the cable was well kinked.
:( Was a new cable
regards
jon
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
MartinMille BANNED
BANNED
Post by MartinMille BANNED »
Hey Jon
You going on the B&B run in March ?
Marty
Jon
Post by Jon »
Marty
Wont have the S2 going by March (was meant to be finished by new year)
Excuse my ignorance, B&B run? when and where? :oops:
jon
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
MartinMille BANNED
BANNED
Bevel & Bush!t Run , Bevels only
Jon
Post by Jon »
Probably not a good idea to rock up on my MKiii then.
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
mizike77
Post by mizike77 »
Did you bead blast the engine complete? No issues of the media getting into places it shouldnt?
79 Darmah
78 900 GTS
86 F1B
80 SSD
02 Harley FXD
72 H2 750 triple
08 KTM 300XC
MartinMille BANNED
BANNED
I was going to ask that before as well , never a good idea to blast media other than Soda, ""It does get in as they as"
Jon
Post by Jon »
mizike77 wrote:Did you bead blast the engine complete? No issues of the media getting into places it shouldnt?
Yes, blasted motor complete.
I made steel plates for intakes, exhausts, starter motor and breather tower, put a smear of silicone both sides before installing then left cure before about 24 hours before I dropped it off.
It then sat around his shop for for about a week before he blasted it.
Pulled off one intake for a look and alternator cover to get back the motor back into the frame so far and no sign of ant blast media in there, so fingers crossed for the rest of them.
regards
jon
1983 900 S2
1983 Mk III Le Mans
1992 Honda VFR400r
1976 CB550f
