Scott's 1975 Ducati 860 GT Special
scott74rv
Post by scott74rv » Fri May 28, 2004 2:44 pm
side
front 1/4
rear 1/4
1975 Ducati 860 GT
$1100 (all prices USD) (purchased 1982)
27K miles, original motor
Disassembled 11-25-2003
Completed 5-8-2004 :D
evan wilcox
http://www.wilcoxmetal.com/
ducati imola alloy fuel tank $1300
road and race
http://www.roadandrace.com.au
front guard fiberglass $57.56
rear guard fiberglass $68.35
transducer boots 2x33 $47.49
tarozzi rearsets w/ rubbers $143.90
battery base fits most twins $27.34
daytona throttle, twins w/grips, black $48.92
clipon handlebars, racing 38mm 7 degrees $111.52
cev lamp assembly round $43.17
selector front arm 72-77, alloy $21.58
oil drain plug (1975 Ducati 860GT) and gasket $21.58
750 Sport Fibreglass Tail Light Bracket $50.36
Fibreglass Chainguard for Singles and V Twins $50.36
road and race order #2
SS 750/900 seat base $106.48
bevelhaven
http://www.bevelheaven.com
throt cables, dual cable set up phf
tach cable smiths
speedo cable smiths GT
clutch cable, set $75.50
air filters - phf and phm cargs, pair $45
aftermarket oil filters, 4x $38
turn signal switch $55
f08 brake pads $23.25
PHF Lever Choke Assembly #8293, (qty 2) $60
bevelhaven order #2
SURFLEX Clutch Kit 860cc > GT & GTS $225
Exhaust Nut Spanner $46
280mm long battery strap $18
Bevel Drive Intake Manifold Gaskets $31
Hydraulic Brake Light Switch KS-0011 $23
Exhaust Gaskets Ducati # 0755.84.030 $12
DUCATI Case Saver Kit 860 GT $25
bevelhaven order #3
Tommaselli Headlight Brkt 38mm $55
Brakeline-750gt-F" - $55 ea, 24.4 inch $55
Pa-Ri SS exhaust clamps $33/pr = $66
http://www.desmo.net
SS kickstart lever 0775.07.305
new number 0769. 07.300 $212.27
jc whitney
http://www.jcwhitney.com
dunstall style pipes, remove baffle, pack w/ glass $110
(would not recommend these pipes)
Broken Arrow Powdercoating $150
804 W elgin 258-1017 scottie
251-2192
C & F Custom Chrome $140
1312 N. Utica
587-1110
Robert / Freddie
2 pipes, 1 crossover, 2 flange nuts
(would not recommend this chrome plater)
IBT Bearings, steering head and wheel bearings $212
11221 E Pine - pine/garnett NW corner
438-8100
Century Plating, zinc plate chassis hardware $60
Ron 835-1482
http://www.eurotechmotorsports.com
ikon shocks, koni replicas
p/n I7610-1418 $225
530-345-7145
Wolfgang Haerter - all italia parts catalog
http://www.angelfire.com/biz/laverda/it ... nframe.htm
Tomaselli clutch lever assembly (Ducati) $40
Blue green CAVIS fuel line (6 feet at 2$2.50) $15
4mm wide stainless clamps (10 at $1.50) $15
http://www.aircraftspruce.com
aurora bearing MM-4
1/4 x 1/4 - 28 UNF Rod End (4 at 5.70) $27.79
bevelhaven order #4
Brembo front brake lever, black $22.50
15mm Brembo front M/C rebuild kit $26.50
black plastic Brembo resv cap $7.75
replacement SMITHS speedo cable $0
bevelhaven order #5
Tank Sticker DUCATI-750S (2) $30
Tail Sticker Ducati-750S-seat (2) $24
Made in Italy Sticker MII-gold $5
CRG Blindsight Mirror (2” Black) $45
http://www.skracing.com
(2) 3211D Pingel Dual Outlet Petcock $64.25 ea = $128.50
w/Reserve (aluminum)
Ducati bevel SS dual saddle $149.49
ivan thelin - hulagun
American Trim (11th and Yale) 1 blk east
Rick 838-9767
Black Leather Mono SS Seat Cover $150
Brembo Brake Lever, Black w/ finger detents $30
miller-specialties (no longer in business)
Clutch Spring Kit $50
TOTAL $5927.18
BIG THANKS to Evan, Steve, Phil, and all suppliers!
Scott
Broken Arrow, OK
USA
Update 11/5/2007
New Avons
Front 100/90-18 56V AM20 Supervenom $84
Rear 110/90-18 61V AM18 Supervenom Universal $89
http://www.swmototires.com
Akront alloy wheels $455 ebay
[email protected]
(Had to re-lace both front and rear!)
Buchannan's Stainless Steel Spokes
http://www.buchananspokes.com
Genuine Conti Mufflers $800 Pair
Road and Race
Engine Rebuild $5434
Syd's Cycles (no web site)
Leaked oil bad, had to re-gasket front jug :-(
Hammer marks on Cam Carriers.
Kind of bummed out, given his reputation.
Right side shift conversion $133
http://www.desmo-ducati.de
Dellortos
36mm new in box $200
local purchase
Headers Ceramic coated
HPC Central
http://www.hpcoatings.com
Clocks rebuilt
North Hollywood Speedo
Brake 11mm Front Master Cylinder - Brembo $96
TAW
http://www.tawvehicle.com
your 860
Post by BevHevSteve » Fri May 28, 2004 5:40 pm
:mrgreen: bella!
:Uwin: That is a beaut Scott, thanks for sharing the photos! That tank is gorgous.
Guest
Post by Guest » Fri Feb 25, 2005 2:53 pm
11/10 for originality!! One of the nicest specials I've seen. Well done Scott.
Chris
