81 SS fresh engine
Gardner
81 SS fresh engine
Post by Gardner » Fri May 24, 2019 7:44 pm
Two rides and 60 miles on a rebuilt engine that came from a crashed Darmah. Engine oil system is modified so all oil is filtered before going to the crankshaft and heads. The primary gears and cover are Brook Henry VeeTwo items but the dry clutch is from a Ducati Monster adapted to fit.
Really makes some interesting sounds.
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
Lumpy
Re: 81 SS fresh engine
Post by Lumpy » Fri May 24, 2019 10:01 pm
Wow!!!! Thats nice!! I`d be interested to know how you went about your full flow filtered oil system. I`m about to attempt something like that on an old GTS I`ve had for years. I`ve been slowly collecting bits and pieces for this project for years and nearly have all i need to get started........just have to finish off a non Ducati project I started first.
I was going to use this method: file: FullFlowConversionHowTo%20(2).pdf
Is this the method you used? Any ideas or pictures you have would be much appreciated. I`ve always marvelled at the engineering master piece the Ducati bevel engine is, but cursed with that crappy by-pass filtering system...............and maybe ignition............and maybe helical cut primary gears......................and slippery clutch................but that power delivery and sound kinda makes up for it all............
Gardner
Post by Gardner » Sat May 25, 2019 8:18 pm
After this busy weekend is over I'll show what was done with the oil pump and filter in the engine and transmission section. I can just add to my
post about better oil flow to the sump.
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
Gardner
Post by Gardner » Mon Jul 01, 2019 3:40 pm
Rode to Kansas last weekend for the AHRMA races at Heartland Motorsports Park in Topeka. Temps in the 90's, don't know how the racers put leathers on and go race. Parked by a pair of Panigale V4's.
Stayed in Gardner Kansas, nice town. Just outside of town is where you could decide back in the 1800's if you were taking the Santa Fe trail to the south or the Oregon trail to the north. The 900SS did 916 hot fast miles with no problems, 2428 miles on the engine now.
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
Post by BevHevSteve » Tue Jul 02, 2019 1:22 pm
good deal - it's always a fun day on a bevel drive..........
Gardner
Post by Gardner » Sun Jul 07, 2019 6:29 pm
Changed oil after Kansas and headed for northern Wisconsin and cooler temps for the 4th of July weekend.
Really nice ride around the Turtle Flambeau Flowage. Back in Davenport Iowa Sunday night after 995 miles.
It's been 3485 miles since May 19th, I'm pretty sure everything done to the engine is going to be okay.
My favorite mod is the dry clutch, with the wet clutch I always had to put it in gear, pull the clutch lever
and kick it over till it freed up.
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
Speedrocker
Post by Speedrocker » Mon Jul 08, 2019 11:55 am
GREAT !!
...one of the last guys, who are ride up really much miles on an L-shaped bevel twin, my respect!
And of course, seems you´ve made it allright with your better oil flow engine..! -*!^-
I wish you a lot more of troublefree and happy miles on that fine bike!
Joe
Gardner
Post by Gardner » Mon Jul 08, 2019 5:58 pm
Thank you Joe! It's so much fun to ride.
Mark G
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
Speedrocker
Post by Speedrocker » Tue Jul 09, 2019 8:50 am
I bet, Mark !!!
I also enjoy it, to ride my MHR at dry weather..!
But to be frank: More than max 400 km`s on a day, i can´t,...than i`m totally exhausted, especially my left hand and lower arm :-D
Greetings from germany,
Joe
Peter Mille
Post by Peter Mille » Tue Jul 16, 2019 6:28 am
I bet, Mark !!!
Joe
I know exactely what you mean... ;)
Speedrocker
Post by Speedrocker » Thu Jul 25, 2019 11:35 am
@ Peter Mille:
Joe
Gardner
Post by Gardner » Fri Aug 30, 2019 5:54 am
I can't believe no one commented about what may be the only bevel Ducati 900SS with beads on the seat! :-D
1978 SD Darmah
1979 SSD Darmah
1981 900SS
2017 Desert Sled
1982 Bimota HB2
Speedrocker
Post by Speedrocker » Fri Aug 30, 2019 9:35 am
Well...everyone have an own fetish... :P :lol: ;)
Joe
