860GT rear wheel hub mystery piece
Posted: Sun Dec 23, 2018 9:30 am
I know that I am likely missing a previous post, but have looked through the ones here, and do not see a match for my question:
Sitting in between the bearings in the wheel hub (not the sprocket hub...) is the piece shown in the link below:
https://www.flickr.com/photos/124760992 ... ed-public/
It is indicated in the Haynes manual, but I do not see it in my parts manual.
Its ends are a close fit to the sides of the bearings, but I do not see its purpose, except to cause either bearing to share side forces (????).
It had quite a bit of grease, but was not packed in it; likely offthrow from the bearings.(?)
Neither end of it shows any wear pattern, adding to the mystery.
Additionally, the ring around it at about 1/3 of the way from its closest end is a mystery to me, as to what it does.
I shall put it back after installing the first new bearing, but will be left with a question and no answer.
Craig? Bill? Anyone? Comments?
Again, thanks in advance.
Richard
Richard
