Bearings Sprocket Carrier 750 S ???
Gday, I thought I would ask first. The bearing in the Sprocket carrier [ cush drive ] on a 73 Sport. Can it be knocked out or does it need to be pressed. Mine in toast. Thanks in advance Gum.
- SSD900 Darmah
Gum, the answer is yes. But it depends on the tools that you have. If you have a press and the right size bars, spacers, tubes, etc. on hand then you can press out. If you have a tool like this one that Steve sells then you can easily knock(pull) them out. You don't want to pound them out with a drift from side to side as this can distort the shape of the hole. The Haynes workshop manual will help you with alot of these questions. I have an extra that I could be persuaded to let go of. BTW does your machine have the original ignition switch and keys? I would really appreciate some info and a pic if possible (see my post under electrics). Jordan
