Break line splitter for 74 GT
Posted: Mon Aug 06, 2007 9:20 am
by gerard collier
Does anyone have a pict of the splitter attached to the lower tripleclamp
want to know correct placement and positioning of switch and banjoes.
my memory is fading faster than I thought !!!!
my splitter is straigth and has 4 openings
Re: Break line splitter for 74 GT
Posted: Wed Aug 08, 2007 6:50 pm
by DesmoDog
gerard collier wrote:Does anyone have a pict of the splitter attached to the lower tripleclamp
A '74 750 GT didn't have dual disks from the factory so there is no correct way to do it... whatever works best for routing the lines should be fine.
My '74 doesn't even have the threaded holes on the triple to mount a splitter. It has the bosses if I remember right, but they aren't drilled/tapped.
Posted: Fri Oct 12, 2007 12:26 am
by ducadesmo
Hi Gerard,
your question is not so easily answered. It depends if you have a GT until around mid 1974 with Scarab brakes or a GT with Brembo brakes.
Also it matters for the Scarab (or earlier Lockheed) brakes, whether you have the European or American version.
On the European versions with Scarab brakes, there was a splitter originally for the brake switch with two smaller hoses (on the American versions usually was no splitter, but a one-piece longer hose) - so, to add the second caliper, you just have to take the longer hollow screw and fix the two hoses on the splitter - this is how it worked on the Sport, which often has been equipped with the twin discs. On the other hand, you need to be cautious to have the twin master cylinder, which is rare to find. All other parts for the Scarab brakes are quite easy to find (I can help you there). If you have the Brembo brakes, you can just take the splitter and all hoses and fittings from a 860 GT or GTS, which is exactly the same. I can send you pictures of both systems, if you want, just contact me.
Regards
Achim from Belgium
Posted: Mon Oct 15, 2007 7:15 am
by gerard collier
Achim
My 750Gt is Early 1974 and has the Brembo master and the rectangular
splitter> If you have a pict of the break lines attached it would be helpfull.
I have already rebuilt the Brembo master and the Scarab caliper
thank`s
Gerard
Posted: Wed Oct 17, 2007 9:22 pm
by baddean
Hi Gerard,
A friend of mine has a 74 GT. I will check with him to see if he has a splitter that I can get a pic of.
Dean
