Brembo Frt M/C 14mm
Panta600
Brembo Frt M/C 14mm
Post by Panta600 »
Folks,
I'm after a 14mm rebuild kit for a Brembo front M/C. Are they still available? Is this a non standard piston rod size diameter? I thought it was a 15mm, but that doesn't fit.
Please help!
Steve
Nothing beats the 4 x 2 seat of a Pantah!
jc_ducati
Post by jc_ducati »
They do exist but not as a "ducati" part.
BMW R100s '81+ rear master cylinder is 14mm by Brembo, and as BMW has a repuation for having all parts for all bikes made then you should be able to get a rebuild kit from a BMW dealer.
I got mine from here:
http://www.motobins.co.uk/displayfinal.php?q=23314
It fits and works.
Hope this helps.
John Clifton
'97 Ducati 916 Senna
'98 Ducati ST4
'82 Ducati SD900 Darmah
'82 Ducati SL600 Pantah
'84 Ducati SL650 Pantah
'03 Ducati 800 Sport
www.caltexducatiracing.com
Thanks for that info, John. I've got a 14mm clutch master hanging around here, and had heard that there was Beemer source for the overhaul kit: but had kinda lost details of what/where/how etc ... ;)
Good!
Btw, I think the Brembo part # is 110.4090.30.
John, if you end up ordering that BMW part please email the BREMBO part number so that I can pursue stocking them here as some Ducati used 14mm, and thus far Brembo has told me they are non existant. Thank you.
jc_ducati
Post by jc_ducati »
The kit came through but it doesn't have a brembo part # on it like the 12mm and 15mm kits I have.
It has a BMW Group part # 34 21 1 242 791
John Clifton
'98 Ducati ST4
izaakb
Post by izaakb »
I picked up this kit as well
It is for a rear master on an R100
I am 99% certain it will work fine. The only thing different is the surface which meets the lever does not have the plastic pad on it as do the other master kits I've seen.
There is no Brembo logo or number anywhere. Even the red brembo flyer is not present, but it includes the Kluber grease and says Made in Italy right below the BMW GROUP info.
1977 500GTL (restored)
1980 Darmah 900SS (being restored)
1986 Alazzurra 650SS
1986 Alazzurra 650SS (project renov)
1986 Elefant 650 (needs work..)
1995 900SS SP #591
1996 600SS
1998 900SS FE
2005 Monster S2R (on my third tank...)
