Hi
My 1st post on this site
I'm chasing a wiring diagram for 1983 900 MHR, having problems with turn r/h signal, started out thinking it was a switching fault, but am now sure it's a bad earth or harness fault, any help would be great thanks
Steve
1983 MHR wiring diagram
- 81mhr900ss
- 750 GT
Re: 1983 MHR wiring diagram
Here's an 81 diagram; I doubt the blinkie wiring is different for the 83. It's common to have issues with the switchgear contacts. I've been lucky but I did take all my switches apart, clean everything and then double check all switch operations before putting my bike back on the road. Grounds are notorious; don't trust anything but your multimeter and even then, wobble and shake things a little while testing.
Good luck,
Rick
Good luck,
Rick
Many thanks
