OEM type wiring
Jholeman
OEM type wiring
Post by Jholeman »
Working on a 250 Diana and I need a new magneto (3 wire) wire and spark plug wire. Anyone know where to find some that look like the original type? Or is a complete wiring harness an option? Doesn't look like there is much to it since no alternator & battery.
Jholeman
1966 & 1968 Ducati Diana 250 Mark III
2006 Ducati ST3
2006 KTM 525EXC
baddean
Re: OEM type wiring
Post by baddean »
Hi J,
I'm a twins guy so I'm not completely familiar with the wiring requirements on your Diana.
What color is your original plug wire? All that I have come across are black. The parts diagrams indicate a two wire cable from the generator.
There is this from Classic Ducati and you might contact them regarding your needs. I think they may have a complete harness as well.
http://www.classicducati.com/index.php? ... ductId=256
And this from Mdina Italia. Also comes in green.
http://www.mdinaitalia.co.uk/cgi-bin/co ... 75546500.1
Sorry can't be more help. All of the restorations I have seen have a black plug wire. Should be easy enough to replicate.
Why don't you have generator and a battery? Is your engine out of a Scrambler?
Hope this helps,
Dean
Hunter S Thompson RIP
Jholeman
Re: OEM type wiring
Post by Jholeman »
Thanks Dean, the Diana engine was I believe the same as a scrambler, no battery just magneto. I'll check out the links.
Jholeman
2006 Ducati ST3
2006 KTM 525EXC
