Does anyone know of a source for the plastic multi-pin connector from the dash to the wiring harness?
I'd like to fabricate a new smaller dash (idiot lights and ignition key)and be able plug straight into the existing harness plug.
Darmah dash connector / plug
Re: Darmah dash connector / plug
I've found the connectors at Radio Shack. You have to look in the component drawers once you get past all the toys,phones,and batteries etc.
So I'm clear -
Not looking for the metal-to-metal connector / pins. I have found a source for those. I need the actual plug.
Hopefully the foto will work...
Note the non-flat edge on one side?
it's a MOLEX connector so google that to find suppliers
- swooshdave
- Diana
Thank you swooshDave.
Looks like an easy solution there. ^>^
