Brake Switch
Gum
750 Sport [BEVEL]
Brake Switch
Post by Gum »
73 Sport rear brake switch, whats the go mine is on all the time. Can they be fixed, thanks Gum
easy enough to figure out if you just always have pressure in the system... Crack a bleed screw with the key on, did the light go out?
If you are talking about the rear brake the switch needs to be cleaned.
Gum
750 Sport [BEVEL]
Tar
Post by Gum »
I will take it off and give it a good clean, lets hope that fixes it.
Thanks Gum
Gum
750 Sport [BEVEL]
Done
Post by Gum »
Had to pull it apart and fit an O ring, the rubber inside was worn, all good now. Thanks Gum
