900 GTS Wires
900 GTS Wires
My new bike is a 78 900 GTS. Its has a directional buzzer, sounds like a bus backing up when you put the directional on. Im guessing this is non stock? Also my front directionals stay lit at all times like a running light. Is this correct? What is the white / red wire running along the frame inside the harness that goes to the fuse box? Mine is very melted, and will need replacment. Thanks, Mike
79 Darmah
78 900 GTS
86 F1B
80 SSD
02 Harley FXD
72 H2 750 triple
08 KTM 300XC
78 900 GTS
86 F1B
80 SSD
02 Harley FXD
72 H2 750 triple
08 KTM 300XC
Hi Mike
I have just about finished sorting my 1979 900GTS. It had virtually no wiring when I bought it and I managed to get a loom and all the switchgear to sort it out. I spent a lot of time and effort researching the electrics on these bikes and the only problem is that there was not a lot of consistency in the wiring on these models as they left the factory so any advice may or may not be right for yours.
The buzzer is definitely not standard and the front indicators should not stay on.
I will check on mine as I do recall a white/red wire.
PM me if you want to discuss in detail.
Steve
Steve
DUCATIS
160 Monza Junior
500 Sport Desmo
900GTS
600SL Pantah
750 Indiana
906
907ie
900SS
750 Lucky Explorer Elefant
ST4s
Others - 1927 Scott, 1950 Monet Goyon
160 Monza Junior
500 Sport Desmo
900GTS
600SL Pantah
750 Indiana
906
907ie
900SS
ST4s
Doing some wiring today. Hve the ignition switch figured out. All is well until I turn the lights on. When the lights are turned on, the red power wire going into the ignition switch gets super hot...would melt if I didnt turn it off. Any suggestions?
79 Darmah
78 900 GTS
86 F1B
80 SSD
02 Harley FXD
72 H2 750 triple
08 KTM 300XC
78 900 GTS
86 F1B
80 SSD
02 Harley FXD
72 H2 750 triple
08 KTM 300XC
