900ss wiring
nottonight68
BLABBERMOUTH
900ss wiring
Post by nottonight68 »
i am about to start rewiring my 76ss
would it be of any use to anyone if i post pics and dimensions of the process?
i ll do it over the next couple of weeks
MartinMille BANNED
BANNED
Post by MartinMille BANNED »
You a full rewire using the old connectors and replace the wiring ?
where are you getting the coded wire from ?
cheers
nottonight68
BLABBERMOUTH
full re-wire,new wire & connectors.
i've worked out colours i need-going to look for in auto electric shop & electrical whole saler.
problem is i may have to it in 100mtr rolls
might have to make up a few looms
nottonight68
BLABBERMOUTH
hey martin
spent a couple of hours looking at my wiring
i originally looked at after market loom-but the price is rediculous,after all its only wire,connectors &heat shrink-cost would be less than$50
anyway i rewired mine in about 1979-since then my son butchered the loom
i have gone through the wiring and simplified it-no crappy fuse box or connectors-therefore i dont think generic loom would fit what i've got
i am going to use 10 different coloured wires and use bullet connectors which i'll cover with heat shrink
bear in mind my thing has no indicators.headlight flash or headlight relay
it seems there may be a need for simple looms at a realistic price
and yes i am an electrician
cheers steve
MartinMille BANNED
BANNED
Sparky ahh ....got any small 2 wire connectors male and female but they must be small
I guess you dont ride at night time ,how do you get it passed for rego ?
nottonight68
BLABBERMOUTH
more info needed on both of those questions
no headlight flash means no function to flash lights by push button
no relay means full headlight current goes through switch,limiting size of lamp-i may install relay to protect nos 1976 switch i just paid a motza for
cheers
nottonight68
BLABBERMOUTH
ps martin
have had the chance to look at the wiring on that new thing you just got
MartinMille BANNED
BANNED
what do you mean ? Have I had the chance to look at whats wrong with it .....No ...not till the end of next week when I will have more parts I can just bolt on to check what is wrong etc etc etc
nottonight68
BLABBERMOUTH
never said there was anything wrong with it
sure looks an interesting bit of gear
i have made some progress on my wiring
i traced out my existing loom -which i built in about 1980
its basically sound but is in poor condition and has been butchered by my sons mechanic
measured everything up &got the relevant wires
am going to upgrade fuses ,install h/light relay&modern engine stop relay
have also sourced orig handlebar switch-extra wires needed there
cheers steve
nottonight68
BLABBERMOUTH
starting wiring today
wont record ,due to lack of interest
Hopper
Post by Hopper »
Post pics. Someone will need them in the future for sure.
Hopper
45deg is halfway there.
nottonight68
BLABBERMOUTH
seems to be indifference-i'll just take my own pics
got the only original 76 switch in existance-needs different wiring
back to the drawing board
