GTS seat buffer
bobnorton
GTS seat buffer
Post by bobnorton »
On the RHS of my seat there is the locating pin on the frame with a corresponding hole in the seat pan,is there supposed to be a rubber cone on the pin to support the seat front?.
ColinS
Re: GTS seat buffer
Post by ColinS »
Just nipped down to the garage to check mine. There is a conical rubber as you describe, it's a bit squashed but measures 17mm at the top, 24 mm at the bottom and is 13.25 mm tall, ID to fit snugly on the pin.
Colin
Colin Steer
Keswick
bobnorton
Re: GTS seat buffer
Post by bobnorton »
Thanks Colin, I have lots of issues, now one less.
