Hi guys!
The Darmah that I purchased a few months ago has a non standard seat fitted. It came with this seat base aswell:
Is the seat itself a separate item as on the whale tail or as I suspect has the upholstery been removed?
Also it looks like the mounting at the front has been modified:
Has the front mount been altered? If so what should it look like and how does it attach to the bike?
Is the upholstery glued directly to the base or is the seat a separate item?
From pictures in the gallery it looks like the seating material extends back under the lifting lid - is this the case?
This is what the bike looks like at the moment :
Again all info much appreciated
Ralph
Late Darmah Seat
My 82 had the same seat and the upholstery was all attached directly to the base and didn't separate, so the whole seat was one unit which didn't come apart, the seat cover did extend under the lifting lid but only to cover the tool compartment thereRalph M wrote: Surely someone can answer this question please. Just need info on how the standard seat mounts to the bike and whether the padded section could be removed from the base ( like the whale tail ) or whether it is one unit.
Can you take a photo with the lid up?
At the front of the base I think that cutout slid under the bolt which held the tank down and at the rear two bolts went up from underneath into the seat base
Eat Right
Stay fit
Die anyway
Stay fit
Die anyway
Oops sorry, I will not spam this forum with non related sales crap any further. [spam deleted by the site admin]
