I'm in the process of getting the sheet metal on my 1975 860GT painted. As most of you know, removing the front fender ("mudguard") necessitates squeezing the two fender/mudguard mounting tabs/tangs off of the mounting studs (4 on each side) towards each other enough to clear the studs. While I have been able to do that successfully, I am going to want to be very careful on re-assembly to not scar the new paint on the mounting studs, and that requires a pretty significant squeeze on those tabs/tangs.
If any of you can provide a technique to do this without scratching the new paint, I will be most thankful. Else, I will have to resort to fighting with the studs to get them unscrewed from the "wheel carrier" (as listed in the parts manual), so that I then have the clearance.
Thanks in advance.
Richard
