750ss squarecase flywheel puller
Posted: Sun Jan 03, 2016 7:40 am
I have a problem with pulling the flywheel off my 750 SS squarecase ...
http://comber.org/img/D750ss/750ss.jpg
The correct puller is very difficult to find because the clearance behind the flywheel is only 2-3 mm and the foot of a standard puller is too thick to fit behind the flywheel.
You can see this on the top and back images...
http://comber.org/img/D750ss/750ssFlywheelTop.JPG
http://comber.org/img/D750ss/750ssFlywheelBack.JPG
This was a notorious problem on the pre-Bosch ignition 750s and I wonder if Ducati have addressed this problem by tapping the primary gear, see the six threads in the photo...
http://comber.org/img/D750ss/750ssFlywheel.JPG
Unfortunately the photo is not directly-on. The diameter of the gear is 79 mm. I wonder what the diameter of the tapped thread is. M8 would be a typical puller thread and this sort of puller may work if so...
http://tinyurl.com/go38jgf
So my questions are;
Are these tapped threads intended for pulling the gear?
Anybody know what thread size they are?
If it pulls the gear, will the flywheel come with it or is that another issue?
Thanks in anticipation,
Eddie, London UK.
Eddie, London UK.
