76 860 crossover shaft problems, still...
If you need technical information or help with your early right hand gearchange 900SS engine - post your FAQs, comments & questions here.
hunde
Post by hunde » Tue Jul 16, 2013 1:01 am
alright, this issue has kept this bike off the road for 10 years - quite a shame..
Years ago, I had the bike getting stuck in gear. Took the selector box to Desomto in SF, and they replaced some springs and shimmed the box.
Finally re-installed it, and immediately it jammed.The issue seems to be that the arr on the end of the crossover shaft (with the pin) pops out of the 'box "C"on upshift. box is perfect on the bench though. Have had several talented and bevel knowledge people look at this and can't figure it out. We actually extended the "C" on the arm 1/4", but it popped right out.
So here are my ideas:
Try to find another crossover shaft "arm" or two to see if I can make some combo work.
Modify arm and c with joints similar to rearset joints. saw one once, so perhaps it would work.
Convert the thing back to rt foot shift. I found this list of parts needed, and I know the shaft that puts splines on outside of the box (shifting spindle 0608.13.20), and I can work it from there. Here is the list:
brake petal 0795.41.100
footpeg mounting stud 0795.69.020
two circlips (or seegers) 735000.1542
return spring for brake petal. . . 0795.41.030
Not too concerned about originality, but don't want it to stand out too much. also don't want aggressive rear-sets, I'm keeping the "Grand Touring" positioning for long range comfort.
Thanks in advance!
Tom in SF
gear shift lever 0601.13.020
shifting spindle 0608.13.200
Re: 76 860 crossover shaft problems, still...
Post by wdietz186 » Tue Jul 16, 2013 4:35 pm
I may have the cross shaft levers buried out in the garage wasteland as I converted my SS to the proper side shifting. It may be a stupid question but have you played with the eccentric adjustment on the shift box?
hunde
Post by hunde » Wed Jul 17, 2013 12:26 pm
Oops, kinda the wrong forum - gonna move it..
Yeah, I have tried just about every combo of adjustability and it still pops. Frustrating...
jockduck
Post by jockduck » Thu Jul 18, 2013 4:25 pm
Hi, You need to rotate the small "C" lever down at least one spline, the pin should stay in the slot for the full movement.
Jock
Jod
Post by Jod » Sat Mar 07, 2015 10:41 pm
Hello Tom
PM me with your email and I can send you some detailed pics of the crossover shaft on my 1976 900SS.
It would be exactly the same I think.
John
Return to “Squarecase Right Hand Gearchange Engines > early 900SS”
