Mille S2 Oil Filter
Peter Mille
Re: Mille S2 Oil Filter
Post by Peter Mille »
The Mahle OC11 will fit the Mille engine without problems.
Right now, I have a HiFlo HF153 on my Mille, but UFI 2310500 and Champion H301 will fit as well, and there are several other brands that will fit too.
No, it doesn't fit, my spigot is M16x1.5 but the Mahle OC11 that I've got has a 3/4`-16UNF-2B thread.
See here.........
https://www.oljemagasinet.se/index.php? ... hle%20oc11
Or has Mahle OC11 got several different threads?
Best regards
Hedton
Peter Mille
Perhaps someone changed it on your Mille..??
Otherwise, all the above mentioned filters will fit the Mille without problems at all.
Do you know if yours is M16x1.5 or the 3/4`-16UNF-2B thread?
Best regards
Hedton
Peter Mille
No I don't, but again, all the above mentioned filters fits my stock 1985 Mille engine without problems.
If they don't fit yours, somebody screwed something up I guess... :?
Peter Mille
Just buy this Mahle OC11 filter ( or one of the others), and you will notice that it will fit your Mille.... :vroom:
Don't make it harder than it is....
I bought this.......
http://www.ebay.co.uk/itm/AN-8-AN8-BLAC ... xy5jxSbx-F
Ebayitemnr:302337834959
With a little machining you can fit a 3/4 UNC filter such as the OC11.
I will take off the anodizing with 5 % of plumbing soda.
Hope this information is useful.
I've modified the spigot i bought.
And the Oc11 filter will now fit.
Peter Mille
Somebody mashed up with your engine in the past, normaly you don't need that device.
Again, any filter for a modern Duc will fit the Mille engine without problems.
The filter is called w77 for the thread 3/4"-16UNF-2B.
https://www.google.com/search?q=w77+oil ... CAw&uact=5
