MHR Mille pistons
Peter Mille
Post by Peter Mille » Sat Oct 08, 2011 2:07 pm
@ Radecal, do you have the new partnumber?
I'll be interested to have two spare sets for my Mille, just in case...
radecal
Post by radecal » Sun Oct 09, 2011 4:22 am
Hi Peter,
I will get them out the shed tomorrow and send the numbers to you.
RAD
Peter Mille
Post by Peter Mille » Sat Oct 22, 2011 12:52 am
Rad, did you find the #'s..??
radecal
Post by radecal » Sun Oct 23, 2011 2:29 am
Sorry mate. I have been away and just got home. Forgot clean about the rings as I was in a bloody hurry to make flights.
Rings are Part Number 12120131A and are marked as "Made in Germany".
Regards and once again sorry about the delay.
RAD
Peter Mille
Post by Peter Mille » Sun Oct 23, 2011 3:06 am
OK, thanks.
So those rings are a direct replacement of the original, excisting Mille piston rings?
radecal
Post by radecal » Mon Oct 24, 2011 3:19 am
Yes, direct replacement. I have already fitted them to my Mille and run them in. No problems. They are correct for the later belties with 88mm bores and supersede the old Mille number in the parts lists.
I got the numbers from a reliable source ie. Arthur Davis (who sent the sets to me as well)
RAD
Peter Mille
Post by Peter Mille » Mon Oct 24, 2011 8:06 am
Thanks, I will order them at a new Ducati dealer ( haven't been in a modern dealership for ages.... :roll: )
Peter Mille
Post by Peter Mille » Mon Dec 05, 2011 12:31 pm
Just to be sure:
I need two rings pro piston, right...?
Eldert
Post by Eldert » Mon Dec 05, 2011 12:56 pm
that part number is for one piston ring set
1 set for one piston . if you have a twin you need 2 sets to serve both pistons
Eldert
Peter Mille
Post by Peter Mille » Mon Dec 05, 2011 1:42 pm
Grazie...!!
Kickaha
Re: MHR Mille pistons
Post by Kickaha » Sun May 06, 2012 8:35 pm
Ok it's been a while, to much other stuff getting in the way but I picked this up today which was the cause of this thread
Before and after
Can anyone spot the difference?
Eat Right
Stay fit
Die anyway
Peter Mille
Post by Peter Mille » Sun May 06, 2012 9:08 pm
No.... ;)
radecal
Post by radecal » Mon May 07, 2012 2:24 am
Good to see you are getting close to finishing the "disaster" recovery.
Head cleaned up ok considering the damage.
RAD
Kickaha
Post by Kickaha » Mon May 07, 2012 3:54 pm
radecal wrote:Good to see you are getting close to finishing the "disaster" recovery.
$800NZ to get to that point and 25 hours of his time, luckily I'm paying "mates rates" and not full workshop rates
There's still a barrel to replate (maybe two) and I'm tossing up about a bottom end strip while it's this far apart, more to check the rod on that cylinder than for any other reason
Eat Right
Stay fit
Die anyway
radecal
Post by radecal » Tue May 08, 2012 4:35 am
Know how you feel. Only just finished doing the heads (new valves, guides) and rings recently and now looks like the cases will have to be split due to a gearbox issue. Bloody frustrating but will look at a crank refresh while it's down.
RAD
