900S2 Identify and problem or two.
JohanM
Post by JohanM »
Hi
I took over my dads bike that stood in a garage for the past 6/7 years. Needed a lot of work, done the frame fairing and electrical but need info on the following:
1. Redone the frame and fairing, except spoiler in front of the engine. Does anybody have an idea where to find an original part?
2. Here are all the numbers I could find on the bike. I know there were 883 900 S2 electric starts, but what does these numbers mean, no numbers is the same? Any idea on the number of the bike ???/883.
Frame: DM 860SS 092143
DGM 13715 OM
Engine: 907399
DM860
Tag: 0759.88.130
9R-13716
3. The bike was parked in a garage for at least 6 years. Redone the electrical circuit with a new wire harness, all electrics work but the motor struggles to turn over, as if not enough power from the battery. Any ideas?? The battery is an 18Ah, 12 V - biggest I could fit in and is also the same as the S2 spare parts list. Any ideas what can be done to improve the start of the bike, as it's been a problem before?
Johan
900 S2 1983
Peter Mille
Post by Peter Mille »
Johan,
An original front spoiler is going to be difficult, try Ebay.
Your frame # is 092143 and engine # is 907399.
They usually don't match.
As for the battery, try a "gel" battery, f.i. from Varta
they have much more cold cranking power than normal battery's.
www.varta.com look at dimensions and find the biggest that will fit.
Cold cranking power is the second digit on the battery, f.i 18Ah 200Ah.
Per Garbos
Post by Per Garbos »
Hi Johan,
I guess, your S2 is from production end of year 1982 and sold as a 83 model, just like the S2 i have.
The first 900 S2 had frame number around 091800 (kickstart and electric)
The numbers are, as far as i can see, right, but there was no belly pan (front spoiler) as standard on those models. It came later -year 84 (red frame and black tank and fairing)
If it is the small spoiler sitting on the fairing, you are talking about, it should be possible to find one from a Pantah.
As already mention, a gel battery will be much better.
Best regards Per
JohanM
Thanks Peter and Per
Post by JohanM »
Yes, the spoiler I was referring too is the small spoiler on the fairing. Some other way that was lost, go figure???
I will search the net a bit to find a spoiler, Pantah or S2. Any idea where to find replicas?
Johan
900 S2 1983
