I upgraded the battery cable to the solenoid.
The load with the original cable was around 77Amps when the startermotor ran.
The loss in the original cable was around 200Watt, according to my mechanic.
I went to a local shop and made a new cable that is around 10mm in diameter.
The difference was huge , the Mille started much faster.
Battery cable upgrade.
Re: Battery cable upgrade.
Always a good thing to do..
The load was about 10 amps lower with the new cable. I`ll have to check the startermotor to see if I Can lower the load.
