Led lamps in the Dashboard
Post by hedton » Sat Mar 03, 2018 11:37 am
Hi!
Has anyone changed the bulbs in the dashboard to LED lamps?
If so can anyone recommend where to buy the lamps?
I want some bulbs that doesn't melt the plastic.
Do you need a resistor if you just change the bulbs and not the socket?
Does anyone know what the socket i s called in the Mille dashboard?
Best regards
Hedton
Cagiva Indiana
Re: Led lamps in the Dashboard
Post by Craig in France » Sun Mar 04, 2018 4:05 am
Has anyone changed the bulbs in the dashboard to LED lamps? If so can anyone recommend where to buy the lamps? <snip>
Yes, Hedton, it has been done (and it's easier to do these days than it used to be). I've had a quick look in my files, but unfortunately I can't find anything up to date with the info you want. If I do, I'll post again.
EDIT
According to Bevelhead Stephen Stepanian, these do the job. And I quote:
"You don't need voltage regulators or resistors for these, like you did the old 5 volt ones in the old "how to" article a few years ago on Ducati Meccanica."
https://shop.advanceautoparts.com/p/alp ... /6460004-P
Does anyone know what the socket is called in the Mille dashboard?
You mean the lower piece of part #34 below? If so, just 'bulb holder', nothing more ... :)
Post by hedton » Sun Mar 11, 2018 3:18 am
Yes nr 34 with a resistor for led lamps.
Post by hedton » Sun Mar 18, 2018 12:40 am
I bought these..
https://www.ebay.co.uk/itm/10x-T5-LED-B ... 2749.l2649
Itemnr:332480267406
I'll report how the work
Peter Mille
Post by Peter Mille » Fri Mar 30, 2018 10:48 pm
I have the same in my Mille.
They are more brighter than normal bulbs, and that's excactely what I wanted, because stock bulbs were dim at daylight, hard to see in a glance.
The leds are just fine for daylight driving, maybe to bright for night driving ( which I don't do anyway...).
